Problems with Saturn V (new)
bybyle
Hello guys,
After finishing the star destroyer, I wanted to keep going during the quarantine with Saturn V.
But here's the thing : I encountered several problems with the model, bercause of them i can't finish it and will never be able to.
Let me explain it quickly :
- the first problem as with the plastic sheet USA : the premade holes were poorly adjusted. I had to make new ones in order to make it fit to the 1-9 piece. If i didnt make new holes, 1-9 piece was juste too big for the USA sheet.
https://imgur.com/a/HQnvhxl
You'll say, easy fix man move on.
So here's the second problem :
- The plastic sheet with the flag : the poles (i dont know how they're called, see pic) are placed so they dont fit in each other. I guess i could make other holes on the flag sheet so the pole would go down a bit but I'm not sure if it would fit.
https://imgur.com/a/fR0hfDf
I was like ok I'll just stop the making of the model and prebuild all the pieces with the plastic sheets so I see if there's any other problems.
And here we go : every single holes in the sheets are badly adjusted, it doesnt fit anywhere.
I took the time to check if I was doing correctly, repeted the steps over and over. It just doesnt work.
Am I the only one having these issues? If not, what am I supposed to do?
Sorry for the poor english, and sorry for not speaking german.
Thanks for your help, I hope it was clear enough..
It seems that you have omitted the black/white part in step 10.
bybyle
The piece isnt black and white yet - it is the white piece you see on top of the USA sheet!
